Gilfammedicine
Jan 21, 2019Aspirant
ReadyNas 212 offline/online Cloud notifications
Evyerday, i get exactly 33 messages saying the ReadyNas is offline and 33 messages that say it is back online. The Online and Offline messages are spaced 2 minutes apart. We haven't had any issue con...
- Jan 29, 2019
Thank you for the reply! We had already set up the DNS addresses on our NIC when the problem started and had setup the NAS with our firewall and Endpoint as well. The problem turned out to be a software issue. I found that there was a new update that we needed and after the update, the NAS has been very quick! I guess sometimes the easiest solution is the correct solution. Since i am new to the readyNAS interface, i missed that it needed an update. I will be checking this on a regular basis now.
Thanks
Marc_V
Jan 22, 2019NETGEAR Employee Retired
Welcome to the Community!
Have you tried setting up DNS addresses on your NIC? or do you have any security software installed on your computer that might block the connection on the NAS. Are you having any Internet connection issues?
Kindly send me a link to your downloaded logs so we can check it as well.
Regards
Gilfammedicine
Jan 29, 2019Aspirant
Thanks
