ColinUK
Oct 29, 2019Aspirant
ReadyNAS 212 USB HDD Size
Hi I have had a look but i can find what the USB HDD size on the NAS supports, im looking at getting a Maxtor M3 4TB USB3 to back up my NAS. At the moment im using a MYBOOKLIVE single disc NA...
Oct 29, 2019Guru - Experienced User
ColinUK wrote:
im getting an error soemtimes as per below when the back up is run, ive set the readynas to remove content on full backup so i assume its a permission problem
Status: Fail: Destination is read-only or files/folders could not be created
Would using a USB drive solve this problem.
Likely it wouldn't show up with a USB drive. But it seems to me you shouldn't be seeing this with the My Book Live.
- Are you using My Book user credentials in the ReadyNAS backup job?
- Have you checked the My Book Live file permissions from a Windows PC?
It can easily handle a 4 TB USB drive.
I don't have any experience with this particular USB drive, though it does seem to be intended for use with a Windows PC (it has some preloaded Windows software, and doesn't list linux as a supported operating system). It probably would work fine, but might need to be repartitioned and reformatted.
