ColinUK
Oct 29, 2019Aspirant
ReadyNAS 212 USB HDD Size
Hi I have had a look but i can find what the USB HDD size on the NAS supports, im looking at getting a Maxtor M3 4TB USB3 to back up my NAS. At the moment im using a MYBOOKLIVE single disc NA...
Sandshark
Oct 30, 2019Sensei
Is anything else also accessing the MyBook? The errors could be because a file is locked as in use by another user. The ReadyNAS cannot differentiate between that and a true read-only file.
- ColinUKOct 30, 2019Aspirant
Hi
The mybook has no user credentials, its all open to any user. The mybook is not used for anything else apart from backup for ReadyNAS
all file permissions are fine from a local PC, i have 4 backup jobs all the same from the nas to the mybook.
all are regular backups through the week then every 4 weeks they will remove the content and do full back up.
Its only when the remove content and full back up runs i get the error message. So it must be struggling to remove a folder and cant write the files again. The mybook is slow for file transfer so this could be the issue. The ReadyNas is deleting the files and tries to write before the Mybook has deleted them.
- StephenBOct 30, 2019Guru - Experienced User
Though it could be timing as you suggest, I'm thinking you might also want to try creating a user on the mybook that does have full permission to the files/folders, and then add those credentials to the backup job.
You could also test the timing theory by backing up a small share with the "remove content" option set.
