Acajohn29
May 13, 2023Aspirant
ReadyNAS 212
Hi, I'm really at the end of my rope. Help would be greatly appreciated. I rebooted my ReadyNAS 21200 about ten times and finally did a factory reset. 24 hours later the situation is exactly the ...
- May 13, 2023
Personally I run Plex on an always-on PC, using the NAS to store the media.
Acajohn29 wrote:
6.10.8
There are a couple of issues.
One is that there is a problem with the Netgear repository for 6.10.8. You can get past that by manually updated to 6.10.9.
The next problem is more difficult, and requires ssh to solve. The NAS runs Debian 8 ("Jessie") Linux, which is quite old. The Debian folks just archived the repositories. The workaround for that is here:
You then can try installing the deb file from Plex directly
Select Netgear, and then choose the RN21x distribution.
May 13, 2023Guru - Experienced User
Is the NAS running properly, other than the issue with plex?
What firmware are you running?
Acajohn29
6.10.8
It says "healthy". I use it as a time machine back up and a Plex Media server, so frankly, I can't tell you whether anything else is working. I just erased everything and haven't tried to set up time machine again.
- StephenBMay 13, 2023Guru - Experienced User
Acajohn29 wrote:
6.10.8
- Acajohn29May 13, 2023Aspirant
Thanks very much, Stephen B. I will try to do what you suggest, (technical abilities may be an obstacle). I will also try to do as you do and load my music to my NAS and run Plex from my computer, (in my case a Mac Mini).
The firmware update allowed me to install Plex but when I launch it it says Firefox can't connect to the server. I imagine the other steps StephenB listed would help remedy that. First I'm going to try running Plex through my Mac Mini.
Thanks very much for your help!
John
