Acajohn29
May 13, 2023Aspirant
ReadyNAS 212
Hi, I'm really at the end of my rope. Help would be greatly appreciated. I rebooted my ReadyNAS 21200 about ten times and finally did a factory reset. 24 hours later the situation is exactly the ...
- May 13, 2023
Personally I run Plex on an always-on PC, using the NAS to store the media.
Acajohn29 wrote:
6.10.8
There are a couple of issues.
One is that there is a problem with the Netgear repository for 6.10.8. You can get past that by manually updated to 6.10.9.
The next problem is more difficult, and requires ssh to solve. The NAS runs Debian 8 ("Jessie") Linux, which is quite old. The Debian folks just archived the repositories. The workaround for that is here:
You then can try installing the deb file from Plex directly
Select Netgear, and then choose the RN21x distribution.
