Lavitz
Jul 27, 2021Aspirant
ReadyNas 2120 v2 lost configuration after blackout
Hi! We have two readynas 2120v2. recently they started to lose whole configuration everytime a blackout happens. When they back online, they forget every settings (Static IP, Disk configuration ...
Sandshark
Jul 27, 2021Sensei
If they are not on an UPS that's linked to the NAS to shut down when the power gets low, that is a risk; but it'[s unusual it happens every time. Any chance your OS partition is getting full?
Lavitz
Jul 28, 2021Aspirant
Thanks Sandshark!
How can we check OS Partition?
- StephenBJul 28, 2021Guru - Experienced User
If you are comfortable using ssh, then you can look at it directly from the linux command line.
The other option is to download the log zip file from the logs page, and look at volume.log. Scroll down until you see this:
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1.1G 2.7G 29% / tmpfs 1.9G 0 1.9G 0% /dev/shm
The blue part is the OS partition.
Scroll down a bit further to see inode use:
=== df -i === Filesystem Inodes IUsed IFree IUse% Mounted on udev 187949 235 187714 1% /dev /dev/md0 1048576 12765 1035811 2% / tmpfs 188839 1 188838 1% /dev/shm
