BySteve
Mar 01, 2024Aspirant
ReadyNAS 214 - All Drives Red!
I can't lose the data. I am in a X-Raid configuration. I have 4 Toshiba 2TB drives install and have been working well. I started to run out of space and bought 4 Seagate IronWolf 8TB NAS Internal...
Mar 01, 2024Guru - Experienced User
BySteve wrote:
My feeling is that the 8TB drive did replicate and then I lost a 2TB drive, so nothing is working. Is this correct assumption?
Unfortunately, likely not.
Download the full log zip file from the logs page in the web ui.
If you need help understanding it, I'd be willing to take a look at it. Put it into cloud storage (dropbox, google drive, etc) and send me a private message (PM) with a download link to the zip. Make sure the link permissions are set so that anyone with the link can view.
You send a PM by clicking on the envelope icon in the upper right of the forum page.
- BySteveMar 02, 2024Aspirant
I really appreciate your offer of help. I really do not understand all the log data. There are a lot of files. What specific files do you need to understand what the issue is and a possible solution?
- StephenBMar 02, 2024Guru - Experienced User
I answered your PM.
Broadly, there are three general causes
- multiple disk failures resulting in a RAID array that can't be assembled
- an out-of-sync RAID array (often a result of a NAS crash)
- An issue with the BTRFS file system (which is installed on the RAID array), resulting in corrupted filesystem structures.
(1) is generally not recoverable.
(2) usually is recoverable, though there will be some amount of data loss.
(3) is sometimes recoverable, it depends on exactly what went wrong.
Thank you for your analysis! So what should be my next step?
