paulies
May 29, 2023Aspirant
Readynas 214 Apps not installing
After a recent question in a previous thread about raid no been good enough I have tried to install some apps and they all fail to install the message I get is "Apps Operation Failed Application filed to install". I have tried install through the apps section and by downloading an image but get the same results, I have googled the problem and tried several fixes but nothing works and from what I have read netgear are not going to be much use.
Anybody any idea what might be up I can run some tests if needed.
Thanks
- SandsharkSensei
See How-I-got-apt-update-and-install-to-work-with-Debian-Jessie . In addition, Netgear screwed up their repository for OS6.10.8, and that (but not what is discussed in the link above) is fixed in 6.10.9.
- pauliesAspirant
Thanks why is nothing ever straight forward 😂 I updated to 6.10.9 but the problem exists.
Thanks for replying 👍
