eddy291
Jul 05, 2020Aspirant
readyNAS 214 new install write speed low
moved across from the wrong forum Can anyone help with low write transfer speeds to a new RN214 with 2x4Tb drives, just installed. It is connected via ethernet to a satellite disk of a BT Whole Ho...
eddy291
apologies for the confusion, the PC and NAS are on separate disks of a mesh wi fi system, neither the "master" or first disk in the system
The volume was fully syncd before I started
If thats the way forward I will try that, it will take a few days before I can do it easily,
Eddy
Jul 05, 2020Guru - Experienced User
The issue is most likely with either the mesh wifi or the NAS itself.
So checking the NAS with end-to-end ethernet is a good next step. If that also has the low performance, then the wifi is ruled out. If it doesn't, then we need to focus on the wifi.
