Don_Pasquale
Sep 11, 2016Guide
ReadyNAS 222 & 224 Release Date Approaching?
Hello everybody,
The ReadyNAS 202/204 was released in Jan. 2015, while the 212/214 in Oct. 2015.
As I'm ready to upgrade from an Ultra 4 (2010), I'm wondering if there are any rumors of a...
Don_Pasquale
Jan 05, 2017Guide
Hello, based on Netgear's CES announcements, would you recommend the 424?
Also I'm trying to find a comparison table to gauge the difference between the 314 and the 424.
Thanks!
Thanks!
Jan 05, 2017Guru - Experienced User
The 424 isn't available yet. You can get some idea of CPU performance from here: http://www.anandtech.com/show/10950/netgear-expands-readynas-lineup-with-intel-denverton-atom-platform. The RN314 uses the 2.13 GHz Intel D2700 dual-core Atom and has 2 GB of DDR3 RAM.
What are your expectations on Plex performance?
- mdgm-ntgrJan 05, 2017NETGEAR Employee Retired
The RN424 is a good new product. It has a newer generation CPU than what was in the RN314.
If you need to transcode using Plex I'd go for the 500 series.
