ejcmdq
May 18, 2021Tutor
Readynas 2304 boot from HDD
Sirs, good morrning. I've installed ubuntu 18.04 in a Readynas 2304. Runs quite fine. Boot menu selection, to boot from HDD don't survive power cycle. It goes back to boot from internal flash dr...
- May 18, 2021
The internal flash is only 128MB or 256MB depending on the model. You can use a syslinux or grub bootloader on the internal flash to chainload onto a hdd i.e. you boot off the internal flash and the bootloader on that switches to booting off a disk.
mdgm
May 18, 2021Virtuoso
You could configure the internal flash to chainload onto the HDD using syslinux or possibly grub.
ejcmdq
May 18, 2021Tutor
Thanks for reply !!
You mean that we can install ubuntu in internal Flash too?
Tks, E!
- mdgmMay 18, 2021Virtuoso
- ejcmdqMay 18, 2021Tutor
Noted thansk for advice !
Tks, E!
Just a doubt... ReadyNas 2304 load a full debian 8 and declares 4G flash, without any HDD.
Is that the same flash are you referring?
Tks, E!
I never had a 2304, so that could be right. The internal flash will have the syslinux bootloader on it.
You could change the normal option in syslinux.cfg to chainload onto the hdd.
