ejcmdq
May 18, 2021Tutor
Readynas 2304 boot from HDD
Sirs, good morrning. I've installed ubuntu 18.04 in a Readynas 2304. Runs quite fine. Boot menu selection, to boot from HDD don't survive power cycle. It goes back to boot from internal flash dr...
- May 18, 2021
The internal flash is only 128MB or 256MB depending on the model. You can use a syslinux or grub bootloader on the internal flash to chainload onto a hdd i.e. you boot off the internal flash and the bootloader on that switches to booting off a disk.
ejcmdq
May 18, 2021Tutor
Thanks for reply !!
You mean that we can install ubuntu in internal Flash too?
Tks, E!
mdgm
May 18, 2021Virtuoso
