BR0KK
Aug 05, 2020Aspirant
ReadyNAS 2304 data Recovery on machine?
Hi, one of my customes uses a RN 2304 with 2x 4 TB in X-RAID. Everything works fine (no errors or downtime so far) but today i was asked to retrieve an defective *.xlsx file from that nas. The...
- Aug 06, 2020
The underlying operating system is Debian Jessie. Yes, you can SSH into the unit. It has to be enabled on the Settings screen of the GUI, then you log in as user root using the NAS admin password. Note that since you are root, you can do things you shouldn't. The warning you get when you enable SSH is based on that -- Netgear will not help you out of a mess you created yourself via SSH. They will not automatically deny support because it is enabled.
With the BTRFS file system that the NAS uses, a lot of undelete tools won't work, and I think what you need to do is recover a delected old version. Here is one that claims it does, though I have no experience with it: btrfs-undelete on GitHub. If Copy on Write is enbled, that may help things out.
Have you tried workbook repair (Repairing-a-corrupted-workbook )? It's probably best to work on a local copy, not the original. There are some other recovery tools for Excel around, too.
Marc_V
Aug 06, 2020NETGEAR Employee Retired
Welcome to the Community!
if you have enabled snapshots for the share where your files are in, it is possible to roll back using the Snapshots but there are things to note though if you will be doing this, one is that any snapshot or data created after the chosen snapshot has been rolled back will be deleted.
https://kb.netgear.com/23405/How-do-I-roll-back-to-a-snapshot-on-my-ReadyNAS-OS-6-storage-system
Not really sure if ReCLAIMe can be used on a working array, perhaps other members will be able to share. You can do SSH via Tech Support mode or by enabling SSH access but only do it if you are comfortable using it.
However, getting the file to open may not need to do recovery. What error are you getting when trying to use the file?
Sandshark
Aug 06, 2020Sensei
