PhotoJoseph
Mar 02, 2021Tutor
ReadyNAS 2312 locking up
(I do wonder why my modle, the ReadyNAS 2312, is not listed in the Model listing when making a new post? That in itself is a little disconcerting!) I have a ReadyNAS 2312 and for the most part it...
PhotoJoseph
Mar 02, 2021Tutor
Ah, the hidden commands you don't know are there ;-)
I've started it, and will report back when it's dond!
Sandshark
Mar 03, 2021Sensei
There is also a lot more information available in the downloaded log .zip file than in the log in the GUI. So much so, it can be daunting to try and find a clue as to what is going on.
When I was having an apparent lock-up problem, I left an SSH session open on a PC with it running top, and I found that the readynasd process was getting to 100% of CPU use and basically locking out most everything else (but, fortunately, not the SSH session and top). The root cause for that probably isn't germane to your situation, but the same process may help find what yours is.
- PhotoJosephMar 03, 2021Tutor
Ah that's helpful. I didn't know the downloaded logs had more. I'll let this disk test finish, then proceed from there. Thanks!
