kebari's avatar
kebari
ReadyNas 2312 SMB Signing
We have ReadyNAS 2312 (RR231200).  It is running the latest firmware (6.10.2).  A security audit notes that the ReadyNAS is allowing unsigned SMB activity.  I have read a couple of threads that discuss users having the same issue, but have seen no real resolution.
I have seen a suggestion to suggestion to directly edit a configuration file - which the person posting noted might not be advisable.
I have also seen a post suggesting that these issues would likely be addressed in version 6.10 of the firmware.  This post was dated 3/20/2019, and the 6.10 firmware is out and intalled on my machine, but the issue remains.
If there is a way to enable SMB signing in this new firmware version, I don't see it.
I am open to suggestions.
  • Install the SMB Plus app.  It's in there on the "Security" tab.  Has been since before 6.10, so I'm not sure why this answer was not given to the other poster.
    • kebari's avatar
      kebari
      Excellent.  Worked a treat.  Thanks for the help.
ProSupport for Business
