Pajuno
Jul 02, 2020Aspirant
ReadyNas 2312 resync after shutdown and automatically uses 90% storage space
The device ReadyNas 2312 was working perfectly for months until we had numerious of unexpected shutdown. Before the cunexpected shutdown we have only use up to 50% of the storage space (12 X 10TB) an...
Jul 02, 2020Guru - Experienced User
You might want to try paid netgear support (via my.netgear.com). Something very strange seems to be happening on your NAS.
Have you downloaded the full log zip, and looked through it? Possibly enable connection auditing, and see if you can track down where the storage is going?
You could also access the NAS via ssh, and look at the full data volume directly - using linux tools to analyze where the space is going.
- PajunoJul 03, 2020AspirantHow do I go about it using Linux. I have a Linux operating system but will it connect since iSCSi if failing to connect? Kindly advise.
Thanks- SandsharkJul 03, 2020Sensei
The NAS operatring system is Linux, and you access it via SSH, which you have to turn on in the GUI. When accessing via SSH, log in as root with the admin password.
What method are you using to determine that 90% of the drive space is used up? Your NAS isn't fast enough to do that in such a short period of time unless it is simply reserving the space for iSCSI.
Kindly check the log
[20/03/06 19:07:48 PST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[20/03/06 19:07:49 PST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/03/06 19:07:49 PST] notice:system:LOGMSG_FIRMWARE_UPGRADED Firmware was upgraded to 6.8.0.
[20/03/06 19:08:39 PST] info:system:LOGMSG_SET_ALERTCONTACT Alert contact information was saved.
[20/03/06 19:08:39 PST] info:system:LOGMSG_SET_ALERTCONFIG Alert settings are updated.
[20/03/06 19:08:56 PST] info:system:LOGMSG_READYNASD_ABORTED ReadyNASOS service or process (readynasd) was restarted.
[20/03/06 19:08:56 PST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[20/03/06 19:08:57 PST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/03/07 04:16:21 CET] notice:system:LOGMSG_DISABLE_NTP NTP is disabled.
[20/03/07 04:27:07 CET] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 10% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
[20/03/09 03:43:26 CET] notice:volume:LOGMSG_RESILVERCOMPLETE_VOLUME Volume data is resynced.
[20/05/29 17:14:16 CEST] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[20/05/29 17:14:17 CEST] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 10% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
[20/05/29 17:14:18 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/15 22:22:44 CEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[20/06/15 22:23:45 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/16 00:44:33 CEST] info:share:LOGMSG_ADD_LUN LUN test was added.
[20/06/16 00:59:26 CEST] info:system:LOGMSG_READYNASD_ABORTED ReadyNASOS service or process (readynasd) was restarted.
[20/06/16 00:59:27 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/16 01:00:28 CEST] info:share:LOGMSG_ADD_LUN LUN TES2 was added.
[20/06/16 01:04:02 CEST] info:share:LOGMSG_DELETE_LUN LUN test was deleted.
[20/06/16 01:07:27 CEST] info:share:LOGMSG_DELETE_LUN LUN TES2 was deleted.
[20/06/16 01:13:28 CEST] info:share:LOGMSG_ADD_LUN LUN PAJUNO was added.
[20/06/16 01:17:36 CEST] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 10% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
[20/06/16 01:20:36 CEST] info:share:LOGMSG_DELETE_LUN LUN PAJUNO was deleted.
[20/06/16 01:22:26 CEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[20/06/16 01:23:29 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/16 01:30:32 CEST] info:share:LOGMSG_DELETE_LUN LUN pajunospace was deleted.
[20/06/16 01:31:00 CEST] info:share:LOGMSG_ADD_LUN LUN PAJUNO was added.
The shutdown triggered this message before the crash
- Logs begin at Fri 2020-05-29 17:13:42 CEST, end at Tue 2020-06-16 20:53:48 CEST. --
May 29 17:14:09 PAJUNO readynasd[4591]: readynasd log started
May 29 17:14:10 PAJUNO readynasd[4591]: readynasd started. (restarted=0)
May 29 17:14:16 PAJUNO readynasd[4591]: Last run started at 1583550536 was aborted
May 29 17:14:16 PAJUNO readynasd[4591]: Detect abnormal shutdown of readynasd and child without core
May 29 17:14:16 PAJUNO readynasd[4591]: ReadyNASOS service or process was restarted.
May 29 17:14:17 PAJUNO readynasd[4591]: Using fan mode: cool
May 29 17:14:17 PAJUNO readynasd[4591]: Less than 10% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
May 29 17:14:18 PAJUNO readynasd[4591]: [createNetworkPortals] Updating iSCSI network portals:
May 29 17:14:18 PAJUNO readynasd[4591]: ResetFailedUnit: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit radar.timer is not loaded.
May 29 17:14:18 PAJUNO readynasd[4591]: ReadyNASOS background service started.
May 29 17:27:44 PAJUNO readynasd[4591]: ERROR: Radar: Maximum iteration exceeded
Jun 15 22:09:22 PAJUNO readynasd[4591]: Could not connect to Replisync socket!
Jun 15 22:09:22 PAJUNO readynasd[4591]: get_replisync_job_status() failed!
