Pajuno
Jul 02, 2020Aspirant
ReadyNas 2312 resync after shutdown and automatically uses 90% storage space
The device ReadyNas 2312 was working perfectly for months until we had numerious of unexpected shutdown. Before the cunexpected shutdown we have only use up to 50% of the storage space (12 X 10TB) an...
Pajuno
Jul 03, 2020Aspirant
How do I go about it using Linux. I have a Linux operating system but will it connect since iSCSi if failing to connect? Kindly advise.
Thanks
Thanks
Sandshark
Jul 03, 2020Sensei
The NAS operatring system is Linux, and you access it via SSH, which you have to turn on in the GUI. When accessing via SSH, log in as root with the admin password.
What method are you using to determine that 90% of the drive space is used up? Your NAS isn't fast enough to do that in such a short period of time unless it is simply reserving the space for iSCSI.
- PajunoJul 03, 2020Aspirant
Kindly check the log
[20/03/06 19:07:48 PST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[20/03/06 19:07:49 PST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/03/06 19:07:49 PST] notice:system:LOGMSG_FIRMWARE_UPGRADED Firmware was upgraded to 6.8.0.
[20/03/06 19:08:39 PST] info:system:LOGMSG_SET_ALERTCONTACT Alert contact information was saved.
[20/03/06 19:08:39 PST] info:system:LOGMSG_SET_ALERTCONFIG Alert settings are updated.
[20/03/06 19:08:56 PST] info:system:LOGMSG_READYNASD_ABORTED ReadyNASOS service or process (readynasd) was restarted.
[20/03/06 19:08:56 PST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[20/03/06 19:08:57 PST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/03/07 04:16:21 CET] notice:system:LOGMSG_DISABLE_NTP NTP is disabled.
[20/03/07 04:27:07 CET] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 10% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
[20/03/09 03:43:26 CET] notice:volume:LOGMSG_RESILVERCOMPLETE_VOLUME Volume data is resynced.
[20/05/29 17:14:16 CEST] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[20/05/29 17:14:17 CEST] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 10% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
[20/05/29 17:14:18 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/15 22:22:44 CEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[20/06/15 22:23:45 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/16 00:44:33 CEST] info:share:LOGMSG_ADD_LUN LUN test was added.
[20/06/16 00:59:26 CEST] info:system:LOGMSG_READYNASD_ABORTED ReadyNASOS service or process (readynasd) was restarted.
[20/06/16 00:59:27 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/16 01:00:28 CEST] info:share:LOGMSG_ADD_LUN LUN TES2 was added.
[20/06/16 01:04:02 CEST] info:share:LOGMSG_DELETE_LUN LUN test was deleted.
[20/06/16 01:07:27 CEST] info:share:LOGMSG_DELETE_LUN LUN TES2 was deleted.
[20/06/16 01:13:28 CEST] info:share:LOGMSG_ADD_LUN LUN PAJUNO was added.
[20/06/16 01:17:36 CEST] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 10% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
[20/06/16 01:20:36 CEST] info:share:LOGMSG_DELETE_LUN LUN PAJUNO was deleted.
[20/06/16 01:22:26 CEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[20/06/16 01:23:29 CEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/16 01:30:32 CEST] info:share:LOGMSG_DELETE_LUN LUN pajunospace was deleted.
[20/06/16 01:31:00 CEST] info:share:LOGMSG_ADD_LUN LUN PAJUNO was added. - PajunoJul 03, 2020Aspirant
Kindly find systemd-joirnal
-- Logs begin at Fri 2020-05-29 17:13:42 CEST, end at Tue 2020-06-16 20:53:48 CEST. --
Jun 16 19:10:18 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 19:10:18 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 19:10:18 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 19:10:43 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 19:10:43 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:45:38 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:45:38 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:45:43 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:45:43 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:45:43 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:45:48 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:45:48 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:45:48 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:45:53 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:45:53 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:45:53 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:45:58 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:45:58 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:45:58 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:03 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:03 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:03 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:08 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:08 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:08 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:13 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:13 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:13 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:18 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:18 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:18 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:23 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:23 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:23 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:28 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:28 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:28 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:33 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:33 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:33 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:38 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:38 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:38 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:43 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:43 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:43 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:48 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:48 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:48 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:53 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:53 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:53 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:46:58 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:46:58 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:46:58 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:47:03 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:47:03 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:47:03 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:47:08 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:47:08 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:47:08 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:47:13 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:47:13 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:47:13 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:47:18 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:47:18 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:47:18 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:47:23 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:47:23 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:47:23 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:47:28 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:47:28 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:47:28 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:47:33 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:pajuno:79e259f1:tes2group in Storage Node
Jun 16 20:47:33 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:47:33 PAJUNO kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:patrick:49cf3115:pajuno in Storage Node
Jun 16 20:53:43 PAJUNO kernel: iSCSI Login negotiation failed.
Jun 16 20:53:47 PAJUNO dbus[4419]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
Jun 16 20:53:47 PAJUNO dbus[4419]: [system] Successfully activated service 'org.opensuse.Snapper'
Jun 16 20:53:48 PAJUNO readynasd[4583]: Error: Connection failure: Connection refused
Jun 16 20:53:48 PAJUNO systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 15557 (sysctl)- StephenBJul 03, 2020Guru - Experienced User
If you are willing to try another factory reset, can you isolate the NAS from the servers that are trying to use it first?
For instance, put it on it's own vlan, with just the management PC. Then do the reset (and don't recreate the LUNs right away).
Then see if the space goes up the same way.
- PajunoJul 03, 2020AspirantIt works fine without creating a LUN. Once the LUN has been created, it revert to the same issue. Do you think I should try downgrade the firmware to an older version that is compatible with the device?
