Pajuno
Jul 02, 2020Aspirant
ReadyNas 2312 resync after shutdown and automatically uses 90% storage space
The device ReadyNas 2312 was working perfectly for months until we had numerious of unexpected shutdown. Before the cunexpected shutdown we have only use up to 50% of the storage space (12 X 10TB) an...
Jul 02, 2020Guru - Experienced User
You might want to try paid netgear support (via my.netgear.com). Something very strange seems to be happening on your NAS.
Have you downloaded the full log zip, and looked through it? Possibly enable connection auditing, and see if you can track down where the storage is going?
You could also access the NAS via ssh, and look at the full data volume directly - using linux tools to analyze where the space is going.
Pajuno
Jul 03, 2020Aspirant
The shutdown triggered this message before the crash
- Logs begin at Fri 2020-05-29 17:13:42 CEST, end at Tue 2020-06-16 20:53:48 CEST. --
May 29 17:14:09 PAJUNO readynasd[4591]: readynasd log started
May 29 17:14:10 PAJUNO readynasd[4591]: readynasd started. (restarted=0)
May 29 17:14:16 PAJUNO readynasd[4591]: Last run started at 1583550536 was aborted
May 29 17:14:16 PAJUNO readynasd[4591]: Detect abnormal shutdown of readynasd and child without core
May 29 17:14:16 PAJUNO readynasd[4591]: ReadyNASOS service or process was restarted.
May 29 17:14:17 PAJUNO readynasd[4591]: Using fan mode: cool
May 29 17:14:17 PAJUNO readynasd[4591]: Less than 10% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
May 29 17:14:18 PAJUNO readynasd[4591]: [createNetworkPortals] Updating iSCSI network portals:
May 29 17:14:18 PAJUNO readynasd[4591]: ResetFailedUnit: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit radar.timer is not loaded.
May 29 17:14:18 PAJUNO readynasd[4591]: ReadyNASOS background service started.
May 29 17:27:44 PAJUNO readynasd[4591]: ERROR: Radar: Maximum iteration exceeded
Jun 15 22:09:22 PAJUNO readynasd[4591]: Could not connect to Replisync socket!
Jun 15 22:09:22 PAJUNO readynasd[4591]: get_replisync_job_status() failed!
