Drunkenspyder
Jan 25, 2020Aspirant
ReadyNAS 2312 Resyncing Never Seems to End
Hello All: I am new to NetGear NAS models. I've been using Synology devices for years. Recently, my Synology 2416RP+ failed when a PG&E power shutdown managed to get through tripp-Lite protector ...
- Jan 25, 2020
Download the log zip package and take a look at mdstat.log to see what drives are included in the array. The default should have been to create a RAID6 unless you changed to FlexRAID mode and told it to do something else.
If you have trouble interpreting, just cut and paste from the log into a message.
Once your NAS stops all the re-syncing, the noise will settle down quite a bit. But any time it sees a lot of activity, the fan speeds will increase, and so will the noise.
Sandshark
Jan 25, 2020Sensei
- DrunkenspyderJan 25, 2020Aspirant
Will do. Thanks much.
