pumpichank
Mar 06, 2025Luminary
ReadyNAS 312 Firmware update connection problems
I've had this ReadyNAS 312 for ages. I can imagine it could be out of support, but I have regularly updated its firmware over the years. It's currently running 6.10.10 but now when I hit Check For ...
Mar 06, 2025Guru - Experienced User
pumpichank wrote:
I've had this ReadyNAS 312 for ages. I can imagine it could be out of support, but I have regularly updated its firmware over the years. It's currently running 6.10.10 but now when I hit Check For Updates, all I get is a connection error. Is this a problem with Netgear, the update server, or is my device just so old Netgear will never support it anymore?
All ReadyNAS are end-of-life.
I have asked whether the update server will come back on line, but so far Netgear hasn't responded.
pumpichank
Mar 14, 2025Luminary
Ah, that's unfortunate. I wish Netgear would at least publicly acknowledge the problem and whether the outage is permanent or not.
