mobiusnz
Apr 05, 2022Aspirant
ReadyNAS 313 - 6.2.0 - Can't remove Snapshot
So I have a readynas that years ago was using snapshots. That Share is barely used now (One folder only). It says it has Zero snapshots but there is a snapshot with a c_2018_07_12__00_00_13 folder in...
- Apr 05, 2022
Forcing the snapshot upgrade can only be done in 6.4.0 and later.
Anyway 6.2.0 was the first firmware with the new snapshots and was released many years ago. You shouldn't still be running firmware that old.
/data/Backup/.snapshots/1/snapshot is a new snapshot.
mdgm
Apr 05, 2022Virtuoso
mobiusnz
Thanks for that info. At least I have a plan now. I’ll get the firmware updated after backing up the critical data.
- Jun 06, 2017Retired_Member
