hunger's avatar
hunger
Apprentice
Jan 24, 2015
ReadyNAS 3130
Finally, an Intel-based replacement for the ReadyNAS 2100 has arrived, in the form of the ReadyNAS 3130. I am trying to figure out which disks are compatible with it. Looking on the Hardware Compatibility List Hard Disks at http://kb.netgear.com/app/answers/detail/a_id/20641, there is no selection for the 3130. Anyone have any idea which disks are compatible with it? Can I assume that the disks for the 3220 are compatible with it?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I have just asked about this. I think that would probably be likely. I don't think you could go too far wrong with e.g. the WD RED Pro.
    mdgm-ntgr
    The 3130 and some drives for it have been added to the HCL
ProSupport for Business
