Hazimil
Jul 12, 2014Aspirant
ReadyNAS 314 - Recommended UPS?
Hi I have a ReadyNAS 314 in the post, and am thinking about a UPS as well. Can anyone recommend any UPS which this ReadyNAS model supports? I would prefer an APC model (as have used them before)....
Hazimil
Aug 01, 2014Aspirant
Hi, sorry for all the questions, I'm new to this! :)
From what I can see, the ReadyNAS 314 uses 69W at Full Power, my computer monitors use (95W, 145W, 145W) and my PC has a 750W PSU. I plan to get a wattage tester to see how much wattage is actually being used. Mainly I just want to protect the NAS, anything else is a bonus.
The BE700G-UK runtime is at: http://www.apc.com/products/runtime_for ... sfamily=29
And the Spec sheet says it has a USB port: http://www.apc.com/products/resource/in ... E700G%2DUK
So, apart from calculating my wattage of the PC/monitors, it looks like this UPS would suffice? Would you agree?
Jonathan
Jonathan
- Apr 03, 2016Retired_Member
