Hazimil
Jul 12, 2014Aspirant
ReadyNAS 314 - Recommended UPS?
Hi I have a ReadyNAS 314 in the post, and am thinking about a UPS as well. Can anyone recommend any UPS which this ReadyNAS model supports? I would prefer an APC model (as have used them before)....
vandermerwe
Aug 01, 2014Master
I have 2 of those, they do have USB connectivity and are compatible with readynas.
I have one that protects an ultra 6+ with 6 disks and the readynas reports about 40 minutes of battery backup time.
I have another supplying a 316 with 5 drives, a 16 port gigabit switch, and a PC with a 400W power supply, readynas reports 16 minutes backup time.
Not sure how accurate these times are; and of course you'd normally set to shutdown well before max battery backup time.
It works for me but I just need enough time for everything to shut down cleanly, nothing more.
- Apr 03, 2016Retired_Member
