OldSchoolGuy
Jun 30, 2023Aspirant
ReadyNAS 314 Having Issues
Hi all, just joined the forum so I apologize if this isn't in the right place. I recently aqqauired a ReadyNAS 314, and i factory rest it and all, was working fine up until today. First i am trying ...
Jul 01, 2023Guru - Experienced User
OldSchoolGuy wrote:
Hi all, just joined the forum so I apologize if this isn't in the right place. I recently aqqauired a ReadyNAS 314, and i factory rest it and all, was working fine up until today. First i am trying to delete folders in the shares (locally am trying to delete) and i get a undifnded "error message" to make things weirder, when i created a share on my readynas (locally again) on my mac, the share name comes up as something totally different. the first letter is correct, but the rest is wrong with a ~
What firmware is the NAS running?
Are you creating the share from the NAS web ui? Or are you trying to create a folder in the root of the data volume from the Mac?
Have you tried deleting the folders from the NAS web ui? Go to the shares tab, and select "browse". You can also delete from there.
I suggest downloading the full log zip file, as that likely has clues on what is going on. We can help interpret it if you need that. Getting it sooner is good, as the logs do rotate, and if you wait the clues we need might be rotated out.
OldSchoolGuy
Jul 01, 2023Aspirant
To be a bit more clear, it does actually delete the file/picture that I press the delete button on, but before then I get the ‘undefined’ error message.
