whetsel
Dec 17, 2023Aspirant
ReadyNAS 314 incorrect consumed storage reporting
I have been moving some large files around and have tried running a balance but something is incorrect about my storage reporting in FrontView. I have a ReadyNAS 314 running the latest firmware (...
- Dec 18, 2023
whetsel wrote:
I may also try: (not sure /mnt is the correct location to run this against)
btrfs balance start /mnt
It's not. Normally mount is an empty folder in root.
No idea why the command did something to the data volume on Sandshark's system back in 2016.
whetsel wrote:
If this doesn't work, what the heck are my next steps?
Obviously it would be prudent to have an up-to-date back up of the data.
You should be using btrfs commands for your troubleshooting - the usual linux commands do not give the right answers for btrfs.
btrfs fi show /data btrfs fi df /dataYou can check if you deleted all the snapshots using this:
btrfs subvolume list -s /dataThis will also give more details
btrfs fi du -s /data/sharenameThis last command can take a long time to complete. You can leave off the -s, but you will get a lot of output.
Note also you can use it (with or without the -s) on subfolders of the share, or even individual files.
Dec 18, 2023Guru - Experienced User
btrfs fi show /data
btrfs fi df /data
whetsel
Dec 18, 2023Aspirant
StephenB thanks for the replies.
I ran the btrfs commands you wrote out sans the one the last one, here were the results:
root@NAS:~# btrfs fi show /data
Label: '2fe61160:data' uuid: c85f4904-6807-44ea-9295-dffc33cd23be
Total devices 1 FS bytes used 13.85TiB
devid 1 size 16.36TiB used 16.02TiB path /dev/md127
root@NAS:~# btrfs fi df /data
Data, single: total=15.98TiB, used=13.84TiB
System, DUP: total=32.00MiB, used=2.25MiB
Metadata, DUP: total=15.50GiB, used=11.62GiB
GlobalReserve, single: total=512.00MiB, used=0.00B
root@NAS:~# btrfs subvolume list -s /data
root@NAS:~#
The balance I started last night via SSH is still running this morning, but I am happy to report that having just log into FrontView it is now reporting correctly. I rushed the post last night in concern, but it appears a balance indeed fixes things. Not sure why the GUI balance did not vs the one I ran from SSH is working.
PS. Thanks for confirming that /mnt was the wrong location for the "full balance". I could not for the life of me think how that helped them, I was going to run it against /data but won't now.
- StephenBDec 18, 2023Guru - Experienced User
There a balancing between speed of the balance and the amount of space reclaimed.
The GUI was probably using a higher threshold for -dusage, which wouldn't compact as many blocks.
You could try running balance a couple of times with successively smaller -dusage values - it likely will free up a bit more space. Best not to go to -dusage=0 in one step - that can take a very long time, and might also run out of working space for the compaction. Lowering it gradually usually results in each step completing quickly.
