EHCanadian
Dec 05, 2019Star
ReadyNAS 314 replacing the ReadyNAS 6 OS
Has anyone replaced the os sucessfully with a clean install of debian or prefered linux distro? I'm under the asumption that the built in flash memory has a limit of 4gb, that 4gb is mirrored to the...
Dec 05, 2019Guru - Experienced User
EHCanadian wrote:I'm under the asumption that the built in flash memory has a limit of 4gb, that 4gb is mirrored to the raid volume.
No. The operating system is installed onto the OS partition (which is mirrored on all the hard drives as RAID-1). But the flash is not mirrored to the OS partition on the disks. It contains the boot loader, the install image for the disks (for factory installs or OS recovery), and the minimal system that is used when you boot into tech support mode.
If you google, you'll find some folks who've apparently done this with the RN102 and RN104 (both arm platforms). No idea how to adapt those steps for the RN314.
- EHCanadianDec 05, 2019Star
You are correct regarding the: The operating system is installed onto the OS partition (which is mirrored on all the hard drives as RAID-1)
Unfortunately I am unable to edit my initial post. I will report back once my atempts(s) have been executed.
