RT6507
Jan 27, 2023Tutor
ReadyNAS 316 (6x4TB Enterprise) - No volumes after graceful shutdown and restart
I shutdown my RN316 while leaving for a few days. Upon restart, I was able to connect and access normally. However after about 15 minutes when I tried to save a file to the NAS I was not able to acce...
Feb 01, 2023Guru - Experienced User
RT6507 wrote:
The first command (--assemble) did not succeed.
The second command (--examine) returned a list of partitions but only one that referenced /dev/sdf1. I tried "mdadm --assemble --really-force /dev/sd1" but got the mdadm error: "device /dev/sdf1 exists but is not an md array."
Not a good sign. sdf3 was identified as part of the array in the logs, but that was 26 January. sdf1 would normally be part of the OS partition - so also part of an md array (just not the data volume).
You could try powering down, and putting sdb back into the NAS. Then go back into tech support mode, and try
mdadm --examine /dev/sdb3
Note the event counter (if it gives you one). Then also run
mdadm --examine /dev/sda3
and see how the event counter compares.
RT6507
Feb 01, 2023Tutor
Replaced Disk 1 (sdb3) and restarted in Tech Support mode. I see six blue LEDs alonside drive caddies. Ran mdadm --examine on sdb3 and sda3 but did not see any event counters. I also ran mdadm --examine on sdf3 and saw the same results.
If I didn't know better I'd think the drives were fine.
Screen shots on cloud.
- StephenBFeb 01, 2023Guru - Experienced User
/dev/sda3 Events: 16711 /dev/sdb3: Events: 16711 /dev/sdf3: Events: 16702This is a bit odd, since last time mdadm told you sdf3 wasn't in an array.
A bit more odd is that disk 2 appears to be in sync (the event counter matches sda3)..
I think the next step is to power down, remove sdf, and power up normally, and see what happens. If the volume does mount, then back up the data before doing anything else.
- RT6507Feb 01, 2023Tutor
No luck. Can't access old Windows Shares. WebUI shows all 5 drives healthy but "no volumes exist". I uploaded a screen shot of WebUI status.
- AnishaAFeb 02, 2023NETGEAR Employee Retired
Hello RT6507
Please see the volume logs once and please find whether the md127 is mounted.
If md127 is not mounted then please mount the volume using the below command
df -h
cat/ proc/partitions
mdadm -A --scan
We offer paid data recovery service.
Note: Data recovery is to investigate whether the data can be recovered. We do not promise to recover the data. Data recovery is paid to check and investigate.
Have a lovely day,
Anisha A
Netgear Team
- RT6507Feb 02, 2023Tutor
Uploaded System-log zip to cloud storage.
I don't see a mention of md127 in the Volume.log. Would I issue the mdadm mount commands from Tech Support mode as Telnet session seems refused with NAS_IV in standard bootup?
OK. ran df -h and others from Telnet - Tech Support mode.
error on 2nd cmd: "-sh: cat/: not found"
mdadm: "/dev/md/data-0 assembled from 4 drives and 1 spare - not enough to start the array."
Screenshot uploaded.
What are the terms for data recovery from you?
Also, tried these commands with all six drives installed and got slightly different messages. See uploaded screen shot.
- RT6507Feb 03, 2023Tutor
Hi StephenB.
I wonder if you saw my last logs and screen shots uploaded to Box? Do you see any hope to continue trying to restore my RN316 to normal operations or should I shift to a data recovery focus. Either way, Thank You for your insight and patience in trying to help me resolve this problem. Your instructions have been clear and concise. I'm grateful for your help. If its time to admit defeat I'll know we tried our best.
- RT6507Feb 04, 2023Tutor
Anisha A
Can you provide more information on Netgear data recovery service, such as costs and what you would need to access my NAS? Thanks.
- AnishaAFeb 05, 2023NETGEAR Employee Retired
Hello RT6507 ,
The basic pay for data recovery service would cost around 200 USD. And we would need SDM to do the data recovery process.
Have a lovely day,
Anisha A
Netgear Team - RT6507Feb 06, 2023Tutor
OK. What is "SDM"?
I'm assuming SDM is through remote access, right? How do we get this recovery process started?
- StephenBFeb 06, 2023Guru - Experienced User
Yes, when you enable it, Netgear can access the NAS remotely.
You need a contract for it. AnishaA should be able to help facilitate that.
