jguz007
Jan 23, 2024Aspirant
ReadyNAS 3220 not accesible from workstation
Drives seem healthy & was wondering how I can get the data? I'm thinking about re installing the NAS OS. Will I lose my data on my drives if I do? Any other recommendations? Thanks!
jguz007
Thanks for the replay!
I cannot log into the web interface. It does not come up. I have not tried to access in explorer but I'm guessing it would be the same being when I ping the IP, I don't get a response.
Jan 23, 2024Guru - Experienced User
Ok. Have you tried to reboot the NAS?
Also, have you tried getting status from RAIDar?
- jguz007Jan 23, 2024AspirantThanks for the response!
I've rebooted several times.
I have not tried RAIDar.
Thanks again.- StephenBJan 23, 2024Guru - Experienced User
If it can find the NAS, it might be able to download logs or run diags.
If you've never installed it, you will need to install Java 8
So I have to install Java on the workstation? It is a production workstation so not sure if I can do that.
BTW, is it possible the NAS OS is cooked? It hung and then I rebooted it and it never came back up.
I read Netgear documentation and saw an option to re install the NAS OS. I'm curious if this will wipe out
my data on my RAID?
Thanks again!
