jguz007
Jan 24, 2024Aspirant
ReadyNAS 3220 not working - Can I put the drives in an identical ReadyNAS3220 without ...
ReadyNAS 3220 not working. Boots up but no Web interface. Can I put the drives in an identical ReadyNAS3220 without losing any data? They are both the same model, I just need the data from the N...
jguz007
thanks for the reply!!
For the record, I will not lose any data on my RAID10 complex by moving them to another chassis, correct?
Jan 24, 2024Guru - Experienced User
Correct.
- jguz007Jan 24, 2024Aspirant
Just swapped the drives. What IP will the new chassis have with the swapped out drives?
I can't seem to reach it on its old IP?
THanks!- StephenBJan 24, 2024Guru - Experienced User
Did you try putting the disks from the working NAS in the failed one, and see if the failed one then boots up?
Also, did you try pinging that NAS when it is powered (but diskless)?
RAIDar is the easiest way to find the IP - it uses ethernet broadcast, so it can find it even if it is not compatible with the subnet. It does require Java, and I do understand you might need to get permission to install it. But it can be on any PC.
Of course if you know the hostname of the failed NAS, you can also try that.
But to answer your question - it depends on how your network is configured.
- If failed NAS had a static IP address (configured in the NAS itself) then the working NAS would end up using the same address. That's because the configuration files are all on the disks.
- If the failed NAS was configured to use DHCP, then the NAS would get whatever address the router assigns to it. If you reserve addresses in the router, then the working NAS would continue to have the same address it had before you swapped the disks. That is because the reservation depends on the mac address of the NIC, and is not in a configuration file.
- SandsharkJan 25, 2024Sensei
And keep in mind that if you cannot access the second NAS with the drives from the first, that's a sign that you have a software issue, not a hardware one. In the other thread, we were giving you options to figure out which kind of problem you have. Swapping all the drives into another NAS is even faster, we just didn't realize you had that option.
