TheDoctor165
Jul 08, 2019Aspirant
ReadyNAS 424 All Lights Blinking (front panel cross and drive lights)
What does it mean when all the lights are blinking on your ReadyNAS 424? I had to pull the power plug to reboot. It rebooted fine buy I had no connection to use the website to reboot and the button ...
TheDoctor165
Jul 12, 2019Aspirant
Marc_V wrote:
Have you checked RAIDar for the status of the NAS? Can you download the logs from RAIDar and send it to us through PM?
Regards
I tried replying to your message with the logs (they downloaded from the admin page in a zip file), but the reply application won't accept a zip file. I tried PMing you by clicking on your name but the PM reply has no file attachment mechanism. I also searched my ReadyNAS page for RAIDar but found nothing. Sorry, but could you give me more detailed instructions or a link to them?
Jul 12, 2019Guru - Experienced User
TheDoctor165 wrote:Sorry, but could you give me more detailed instructions or a link to them?
You put the zip in cloud storage (google drive, dropbox, etc), and send a link in the PM. That avoids the need for any attachments.
- TheDoctor165Jul 12, 2019Aspirant
Ok... thanx! That expains it. I will have to set something up as I do not use cloud storage solutions. I'll post a link as soon as I have somethings.
Turns out I did have a google drive account I set up quite some time ago and used once or twice, but forgot about. I uploaded the log file... here is the link: <REDACTED>
I have never done this before so hope it works, lol.
Regards and thanx in advance
- StephenBJul 12, 2019Guru - Experienced User
Send it in the private message, don't post it publicly!
I redacted the public link. BTW, it did work.
Since I had a link, I did take a quick look. Wait for the mods though, as they are more practiced than me on sorting them.
I'm not seeing any problems - other than quite a few
CIFS VFS: cifs_mount failed w/return code = -512
and some
CIFS VFS: Send error in QFSAttributeInfo = -512Also, you seem to be running on a fast ethernet link, not the usual gigabit. Likely not an error, but I'm mentioning it just in case.
