hplcman1972
Nov 30, 2021Follower
ReadyNAS 424 Max USB Drive Size
Hello!
I was wondering if anyone knows what the maximum USB drive size can be for the ReadyNAS 424? I currently have 2-4GB external drives connected and they work fine. But can I go up to 6 or 8GB?
Thanks!
There isn't a known maximum (either for internal or external disks). There won't be any problem with 8 TB (and you could go larger).
- LaserbaitLuminary
I have an 8TB Seagate Expansion on my RN316, so I know that works.
