leo037
Jun 10, 2018Luminary
ReadyNAS 428 memory upgrade
I've been looking around and haven't been able to determine if the memory on the 428 is upgradable.
I've seen that the 2 and 4 bay 4-series has soldered on memory. Hoping this is not the case ...
leo037
OK that's good to see
disappointed there are no reviews of the 428 out there.
I'll definitely open it up when I get mine on tuesday and take a look.
I plan on maxing that thing out if I can.
Frank888
Jun 10, 2018NETGEAR Expert
Please check the existing memory module and use the same ECC or non-ECC configuration module to upgrade.
- leo037Jun 11, 2018Luminary
OK got my 428 a day early.
Have tracked down the DIMM info to this
https://www.transcend-info.com/Products/No-687
4GB model # TS512MLH72V1H
Amazon has it for $101 (???!!!???)
Crucial has a similarly spec'd stick for $49.99 (much better price)
https://smile.amazon.com/Crucial-PC4-2133-Registered-288-Pin-CT4G4RFS8213/dp/B00KK8USSG
Kingston
https://smile.amazon.com/Kingston-ValueRAM-2133MHz-DDR4-KVR21E15S8
Curious to know if anyone at Netgear can speak to how much memory the board maxes out at for ECC and non-ECC?
Intel specs on the C3538 CPU say 256GB. I'm not that nuts to put that much ram into this thing. If it had a beefier CPU or a GPU for Plex then maybe I would.
I'm shooting for 16GB at the moment. Guessing that the board maxes out at 32GB or 64GB?
non-ECC memory prices about the same so looks like ECC is the way to go
- mdgm-ntgrJun 11, 2018NETGEAR Employee Retired
ECC memory is definitely better to use. All installed sticks need to be ECC to use ECC memory. The max memory capacity is 64GB with four modules (so max of 4x16GB modules).
The modules must be UDIMM (Unbuffered DIMM) modules. I can't see unbuffered mentioned anywhere in the description of the Crucial modules on Amazon.
