mcp1434
Aug 13, 2023Aspirant
ReadyNAS 428 RAM Upgrade - need advice
Greetings, I'd like to upgrade the RAM in my ReadyNAS 428. My questions are..... Will it benefit me to upgrade it from the stock 4GB to the max 64GB? Can anyone provide a link to compatible memo...
- Aug 14, 2023
Unless you are running a lot of VM's or some massively memory-hungry apps, you aren't going to notice much difference above 8GB, and you won't notice a lot going from 4 to 8. I can't help you with the memory type, but can only suggest you see what's in it already and try to duplicate the specs.
Sandshark
Aug 14, 2023Sensei
mcp1434
Aug 15, 2023Aspirant
Thanks so much!
