ITGUY1988
Sep 02, 2019Follower
ReadyNas 4312 Optional 10Gbe Modules
Hi, we have a ReadyNAS 4312 model which features 2 x option 10Gbe modules to be installed, is anyone able to advise which 10GBe NIC's to purchase for the above model, thank you
Sandshark
Sep 02, 2019Sensei
The 10GbE of the 4312X is not a user-instal;lable option for the 4312, as best I can tell. I know it's a special mezanine card, not standard PCIe. I also see nothing in Netgear's documentation that says there is any 10GbE option except to buy the "X" version. However, my 4220 is equipped with an Intel X540-T2, which I have confirmed is also recognized by my older 4200V2. It has no Netgear marking and as best as I can tell, it has no special firmware. I don't even know if it came with it, as I purchased used. So, I suspect that one would work just fine in the 4312. But there appears to be only one PCIe X8 slot in a 4312, so you could only install one; and doing so would prevent later installng the SAS controller for expansion modules.
Amazon sells one with a 30 day money-back guarantee, so you could give it a shot (and let us know how it goes). It's a bigger reward with some risk, but they sell for about half price on eBay.
