GuinnessTrinker
Jan 19, 2018Tutor
ReadyNAS 4312S: Operating Temperature
Model: Netgear RR4312S6-10000S ReadyNAS 4312S, 10Gig SFP+ 2U 12-bay Network Attached Storage 12x 6TB Enterprise HDD According to datasheet 2016 Operating Temperature is 0 to 40 °C According to d...
bedlam1
Jan 19, 2018Prodigy
Those figures are for the Operating Environment i.e. the room where the unit is installed
- GuinnessTrinkerJan 21, 2018Tutor
So in 2016 we could operate the NAS at 40°C and in 2017 at 45°C ??
What about 2018?
http://www.netgear.at/business/products/storage/readynas/RR4312X.aspx#tab-technischespezifikationen
-> RR4312X, RR4312S Datasheet is 2016 -> (40°C)
https://www.netgear.com/support/download/
-> Product Data Sheet is 2017 -> (45°C)
https://www.netgear.com/business/products/storage/readynas/readynas-rackmount.aspx#tab-resources
-> ReadyNAS® 3312/4312X datasheet is 2017 -> (45°C)
Is there a difference between SSD and HDD ?
- StephenBJan 22, 2018Guru - Experienced User
The NAS generates heat, so it will always run hotter than the ambient temperature. Using drives that are more power-efficient does reduce the system and drive temps.
SSD power use varies considerably by model, often ranging between 1 watt and 4.5 watts under load. This overlaps the HDD power use - NAS purposed and enterprise class drives generally run between 4 and 6 watts.
The operating temperature range of the disks also might be a consideration. Many SSDs are spec'd to run at 70C, hard drives are usually spec'd at 60C.
So you'd need to check the specific specs of the drives you are considering, and perhaps take both power and the operating temperature range of the disks into account.
How that relates to the data sheet is a bit hard to say, since there always is some margin built into those specifications. But whatever disks you choose, it's best to stay under the current datasheet's ceiling (45C).
How hot are your ambient temperatures? 45C is pretty hot.
