Doblerm
Apr 22, 2020Aspirant
ReadyNas 4312x surveillance video storage issue
We installed a ReadyNas RR4312X with 12x 6TB Seagate SkyHawk Surveillance drives in RAID-50 for Avigilon security camera storage. We started out with 55 cameras and it worked flawlessly but as we are...
Apr 22, 2020Guru - Experienced User
Doblerm wrote:
Respectively they are only showing 750MBps into the unit and 400MBps out.
I am wondering what the needed peak write throughput is, and also the amount of data being collected per day.
Using multiple volumes might help, as seeks would be independent. If you are writing to shares (as opposed to LUNs) then using SSDs for metadata tiering and possibly data caching might also help. Either approach would require using bigger physical disks to keep the same capacity.
You might also look at the CPU load in the performance graphics. RAID-10 would likely reduce the CPU load, since no parity computations would need to be done. It would also reduce the amount of disk I/O needed for writes.
- DoblermApr 22, 2020Aspirant
Thanks for the fast reply StephenB ,
We are a school so the money simply isnt there for SSD drives. Currently we are maxing out the storage with the desired retension rate so changing to RAID 10 would further limit retension unless like you stated we went to larger drives.
I didn't see a CPU performance section. Unfortunately we have been closed for the last 5 weeks (spring break and COVID-19) so the 30-day chart is not represenative of average usage and I am unable to pull specific numbers.
- StephenBApr 22, 2020Guru - Experienced User
Do you have ssh access remotely? If you do, then you can just run top.
- SandsharkApr 22, 2020Sensei
The NAS is just storage, not running the surveillance app itself, correct?
With 16GB of RAM standard, I'd think that was enough, but you could try adding more. While it would require completely re-configuring the NAS, I wonder if it would help to have multiple volumes and the cameras spread out as to on which each puts it's data.
Are the cameras motion triggered, which means the demand fluctuates a lot, or continuous? If motion triggerred, have you noticed the problem worse during class changes when a lot are going to trigger at a time? Of course, modern codecs used by most security software compress unchanging data much smaller than changing data. So even if continuous monitoring is used, the data volume may increase with lots of motion all over campus.
- Nov 24, 2016Retired_Member
