knorman5
Dec 13, 2021Aspirant
readynas 4360 how to replace a drive that was removed by the NAS
I have a redynas 4360. flly loaded. that apparently removed a drive from slot 39 of the 3rd raid volume so. I inserted a compatible drive from another system. when i insert the new drive the drive...
Dec 13, 2021Guru - Experienced User
Did you unformat it first? If it was from another ReadyNAS, the system might have gotten confused.
Not sure what to make of the issue with slot 38, but the best solution for slot 39 is to hot-insert a blank (unformatted) disk. Alternatively, format it as NTFS. Then hot-insert it, and format it again from the NAS volume page.
