mediasurfer
Oct 21, 2015Tutor
ReadyNAS 515 newbie upgrading from WHS
HI I have just purchased a Neetgear ReadyNAS 516 and 6 x Seagate ST4000VN000 4TB NAS HDD. (I have previously been using a HP mediaserver home server WHS which has just failed but I rescued my da...
JennC
Oct 27, 2015NETGEAR Employee Retired
Hello mediasurfer,
I understand, not sure what went wrong there, I tried that on our own unit and I did not have to enter the ReadyCloud accounts on the admin page.
I'm glad all is well now.
mediasurfer
Oct 28, 2015Tutor
Hi JennC
Yes, there is something not quite right, I am not sure if I have set it up correctly, but for my needs at the moment It will be okay. I have all my files loaded on it and I can access them remotely. I have also used the Windows readycloud program and the Apple App. I am now on my way offshore for 2 weeks which will give me the chance to have a good read up and put it through its remote access paces. I will follow up on the issue when I return in a couple of weeks, maybe I will try a telephone support call, thanks for your feedback so far
I understand you tried my issue on your own unit. Are you saying that simply adding a readycloud account under CLOUD will generate a home folder that matches the username, and then that readycloud account will will be able to access all folders without further action
