Kezooz's avatar
Kezooz
Star
Dec 14, 2016
ReadyNAS 516 - Making continual wurring noise?
Hi all   I have recently purchased a Netgear ReadyNAS 516 and installed x4 brand new 6TB Seagate NAS HDD - ST60000VN0021   I have also upgarded the firmware to the latest version 6.6.0   Upon t...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Dec 16, 2016
    If you go to System > Volumes and hover your mouse over a disk there will be a popup with some information including the disk firmware version.
    If you download the logs you can also see the disk firmware version in some of the logs.
    You could hook the disks up to your PC and run the disk firmware update on them.
ProSupport for Business
