Pairofdocs
Jul 22, 2019Aspirant
readynas 516 decided it doesnt exist after adding 2 new WD Red 10tb drives
OK, This is going to be a long one, as I did plenty of things wrong in retrospect, and now I dont want to make any more mistakes going forward in case I can fix this. I will state up front, my main ...
Pairofdocs
Good Stuff. I will try to grab the logs.
JohnCM_S
Jul 27, 2019NETGEAR Employee Retired
Hi Pairofdocs,
I checked the logs. The volume went offline because there is not enough operational disk in the raid array.
Jul 22 21:59:00 chonk kernel: md/raid:md126: device sdb4 operational as raid disk 1
Jul 22 21:59:00 chonk kernel: md/raid:md126: device sdd4 operational as raid disk 5
Jul 22 21:59:00 chonk kernel: md/raid:md126: device sde4 operational as raid disk 4
Jul 22 21:59:00 chonk kernel: md/raid:md126: device sdf4 operational as raid disk 3
Jul 22 21:59:00 chonk kernel: md/raid:md126: allocated 6474kB
Jul 22 21:59:00 chonk kernel: md/raid:md126: not enough operational devices (2/6 failed)
Can you enable the Secure Diagnostic Mode (SDM) on the NAS? We can look a little closer at the issue to see what else is possible. You can enable SDM by going to System > Settings > Support. You may send to me the 5-digit code via PM after enabling it.
- JohnCM_SAug 01, 2019NETGEAR Employee Retired
Hi Pairofdocs,
It looks like the problem with the unit is that the OS is full. We cannot remount the OS from Normal mode. Can we reboot the NAS in Tech Support mode for the meantime? You do not have to be physically near the device. We can boot the NAS in TS mode on our end.
- PairofdocsAug 01, 2019Aspirant
Yes. Please do what you need...even if you lose data, itsmbetter than my current situation.
Best,
Aron
JohnCM_S wrote:Hi Pairofdocs,
- JohnCM_SAug 03, 2019NETGEAR Employee RetiredHi Pairofdocs,
L3 has fixed the OS problem and started working on the data volume problem. The system only has 4 out of 6 drives that are okay. One disk that is on some state and another disk is totally missing , maybe it was the old disk.
We cannot start the RAID probably without that missing disk that had the 4th partition.
