Noverun
Aug 03, 2022Aspirant
ReadyNAS (6.10.5) Configuration Restore
I backed up the configuration and received a Zip folder. When I go to System > Settings > Restore - Browse and select the Zip file or any conf. files within the zip I receive this message "the ba...
Noverun
No name changes. The volumes were 4x4TB now they are 4x8TB.
That is the only change that has been made. I actually didn't know the device would factory reset when i swapped the volumes out. I was giving myself a safety net by downloading that configuration backup for everything just in case something went south. So here we are standing south and the backup file is "damaged"
I can't download it from a different browser now that the config is different. I basically need that config that I already have to work and it seems that I am out of cards to try here.
