munchrazz
Nov 03, 2015Follower
ReadyNAS 600-TL
i installed a 3tb wd hard drive and only 279gb is reconized. i can't locate a compatiblity list for this device??????
siigna
Nov 03, 2015NETGEAR Employee Retired
Only drives up to 2TB in size are supported in the SPARC-based ReadyNAS systems (such as your ReadyNAS 600).
mdgm-ntgr
If you like you can look at the compatibility lists for other SPARC based models.
Under Legacy > ReadyNAS NV+ for instance. Note the NV+ v2 is not SPARC based so don't use that list.
I would consider drives such as the WD RED 2TB or the SeaGate NAS 2TB
