pgjscottieuk
Feb 08, 2022Guide
readynas 626x 10 Gbps LAN port downgrading to 1Gb
readynas 626x keeps downgrading the 10Gbps LAN port to 1gb that i have been using and have been since new two years plus Readynas firmware 6.10.6 connected to Netgear XS512EM switch connected to Net...
Feb 09, 2022Guru - Experienced User
I don't have that particular switch, but from your picture it looks like you select the port on the left, and then select the speed from the pulldown (changing Auto to the speed you want).
pgjscottieuk
Feb 09, 2022Guide
Thank you for your reply i have never made any settings in the switch just used as plug n play do you mean the QOS settings if i play with those will it upset the other things a knock on effect i did move the 626 port further along to see if it made a difference as has happened before after unplugging and plugging back in it is back up to 10gb
