mishanechka
Sep 14, 2021Aspirant
Readynas 6pro does not add a disk to the 6th slot all disks are 3 tb
readynas pro6 system of 6 disks of 3 TB when adding 6 disks to slot 6 nothing happens.
- Sep 14, 2021
mishanechka wrote:
I used the same disk in slot 6, everything was fine, and now, when loading, the device does not even boot if you insert the sixth diskWell, it's either
- the bay
- the disk
- (unlikely) a failing PSU that can't provide enough power for all disks.
After the current resync completes, you can try removing all 5 disks (labeling by slot, so you know where they go).
Then try doing a factory default with the problem disk in bay 1, and see if that works. If it does, then try powering down the NAS, move that disk to bay 6 and try rebooting.
Or test the disk in a PC now, to simplify troubleshooting.
Sep 14, 2021Guru - Experienced User
What firmware are you running?
Do you recall the original size of your volume (when first created)?
- mishanechkaSep 14, 2021Aspirant
firmware 6 10 5. first created about 15 tb xraid
- StephenBSep 14, 2021Guru - Experienced User
Thx. Was the 6th disk already formatted?
If it was, you need to select it on the volumes page (center graphic), and then format it again using the control on the right of the page.
tried to format it differently in fat and in ntfs anyway it does not see it on the picture it is not present - I tried 3 pcs of disks
