Gruncle1
Feb 24, 2020Guide
ReadyNAS and Alexa
I have a NAS 202 loaded with music and hooked to my Orbi router. How can I cxonnect it to Alexa Home Echo?
- Feb 25, 2020
Marc_V wrote:
To have Alexa play Music from the ReadyNAS you will have to use DLNA. You may want to check this Alexa skill.
This particular skill requires you to index your music on a PC, and then upload that index to an OurJukebox account.
Plex also has Alexa integration, so if you are running Plex you could try that. Though I haven't been that impressed with it myself.
Marc_V
Feb 24, 2020NETGEAR Employee Retired
Currently it is not possible to integrate the ReadyNAS system to Alexa, the NETGEAR skill that Alexa has are for the routers as of the moment and it's voice commands are mainly for Router functions like enabling/disabling Guest Network or rebooting the router.
HTH
Regards
- StephenBFeb 25, 2020Guru - Experienced User
