Boodog
Jul 04, 2017Aspirant
NETGEAR's Alexa Integration
I just purchased the C7000 Netgear modem/router. I thought the C7000 can do what the R7000 can do. But I can't get it to hook up to Alexa. Should I return this one and get the R7000 or is there a way to get Alexa hooked up to this model? Thank you
NEVERMIND, I FINALLY GOT IT TO WORK, but I can't figure out how to delete this message.. sorry
Thank you, so am I.. :)
- William10aMaster
Glad you get it to work wish you good luck.
- BoodogAspirant
