Retired_Member
Jul 18, 2017ReadyNAS Balance and ESXI hosts
Model ReadyNAS 4312 (did not have that in Model selection, when creating this discussin). Firmware 6.7.5 *My "setup" ESXi 6.0 EMC SAN for Production Servers (10GB Base-T) Readynas 4312 is use...
- Retired_MemberSep 16, 2017
Just an update, since I really dont like when people dont update a discussion.
On firmeware 6.8.0, and have had a Balance and defrag without issues. (so it seems Netgear has fixed the issue IMO)
Retired_Member
Jul 19, 2017I am guessing at this too, since the ReadyNAS is the only new thing added to my network...when I had my support ticket with VMware the only thing I did to bring back my ESXi hosts....was turn off the ReadyNAS. A few days later I did a "Balance" again.....with same resutls...In vCenter the ESXi hosts stated "not responding"...I could not log into the hosts of each ESXi server. I again shut off the ReadyNAS and all came back online.
mdgm-ntgr
Jul 20, 2017NETGEAR Employee Retired
Your volume doesn't need balancing. It's well balanced looking at the output you've provided.
- Retired_MemberJul 21, 2017
Well I did 2 balancing within a week, the second was really only a test to see if the "issue" would happen again, and it did.
I first did a balance by suggestion from Netgear support.
I will do some testing and disable NIC's on my next balance, I will post updates.
- jak0lantashJul 21, 2017Mentor
Metadata allocation is a bit high. Are you using bit rot protection, compression, etc?
You should disable the quotas on the volume (if you don't have any quotas on the shares).
If you're running databases, maybe you need a faster volume, like RAID10.
That said, I still don't see the connection between the balance and your ESXi hosts.
I will try your suggestions in regards to the quotas and will look at RAID 10.
I will say, if you want to have a webex session, I can show the issue live.
