Nasuser4
Nov 11, 2017Aspirant
ReadyNAS creating C message... what does it mean?
Hi, I purchased a RN314 and was using it for about 6 months. Then one day it stopped working. I performed a USB recovery without success. So I took the 4 drives (X-RAID) and connected it to my old n...
Nasuser4
Nov 12, 2017Aspirant
Thank you SandShark for the information.
Unfortunately, I did not know what I was doing..... and now I am just trying to get back my RN314 working again.
I am hoping that I turned off the unit fast enough to cause minimal loss of data. It was creating the C volume at about 2-4% when i unplugged it from the wall....
Eversince we had a poweroutage at the house, the current NAS was not booting up and was stuck on the booting ... status. I hooked up a display to it and it told me to insert a bootable disk. So I figured that i needed to reinstall the OS via the USB recovery tool. Maybe it got corrupt somehow during the power outage.
I tried various USB sticks, used the "usbrecovery.v2.0.R15-T3", and found a couple of them that gave me the "gpio_it87 unknown chip found 8721 revision4". I spent the better part of a day trying to get it to boot from the USB stick. I several FW versions, including the version that came with the unit (OS 6.4.2)
After that, I tried to enter the boot menu to do a OS reinstall. And was unable to enter the boot menu. I tried it with the drives in and out of the system. There seems to be no way for me to enter the boot menu......
Do you think that the motherboard, RAM, or flash failed? What can I do to recover the NAS?
Do you think that if i get the NAS working again or buy a new RN314 that I can recover the data by using the disks as is with the OS6.X firmware?
Thanks!
Nov 12, 2017Guru - Experienced User
If you power up the NAS with no disks inserted, does it show a "no disks" status? If so, does RAIDar discover it on another PC?
When did you purchase the NAS? Are you the first owner, or is it used?
- Nasuser4Nov 12, 2017AspirantNo, it doesn't get that far. All I get is the Welcome to Netgear and then the Booting ... Message. I am the second user. My brother gave it to me when he upgraded a few years ago.
- StephenBNov 12, 2017Guru - Experienced User
Nasuser4 wrote:
No, it doesn't get that far. All I get is the Welcome to Netgear and then the Booting ... Message.This is with the disks removed? Does RAIDar give you any status?
Your brother can still arrange for support (passing over the fact that he gave it to you). Maybe consider it a loan.
When did he purchase the NAS? His hardware warranty is three years from his purchase date. Also if he purchased between 1 June 2014 and 31 May 2017 then he has free lifetime chat support.
- SandsharkNov 13, 2017Sensei
It's hard to say what happened now that you have done more things to the unit. You may have needed an OS re-install. That's not the same thing as a USB recovery. You may have had a full OS partition, which is made worse by any attempt at installing anything.
From what I have read, the warning message you got during the USB recovery is just a bug and does not affect the ability of the recovery to work. And the fact that you got it means the recovery process at least started.
The first thing is to see if you are covered under warranty to get the NAS working.
As for your drives, the file system structure is going to be damaged. So, as I said earlier, data recovery will be your only hope. Netgear may be able to do it, but it's not included in the warranty.
