RhinoAU
Sep 21, 2020Aspirant
ReadyNAS default credentials not working
So i'm trying to setup my ReadyNAS Pro 6 on a new network (transitioning from an old network) and I've managed to get RAIDar to recognise the device however when I try to access the admin page and put in the username/password it doesn't work. I've tried resetting the OS a number of times and used the default username/password (admin/password) but nothing has worked. Each time I go to input the credentials and press sign in, the pop-up window disappears and then reappears. I've tried using different browsers (I'm currently on chrome) but that hasn't worked too. Any help would be appreciated. Thanks.
If you are running the stock 4.2.x firmware, then the default admin password is actually netgear1.
